1. Vickie_D_80's Avatar
    Hi all,
    Please accept my apologies if I've started this thread in the wrong place, I did search for Galaxy Young but couldn't find a forum.
    My daughter came to me last night, her battery died and her phone wouldn't switch back on despite being plugged into the charger. So I took the battery out, plugged the charger in and put the battery back in. Pressed power on and the phone won't stop vibrating! As soon as you put the battery in, it just goes nuts - continually vibrating.... I plugged it into the laptop but it says device not recognised and the touch screen won't work on the phone in order for me to click media device option, all the while the phone is continually vibrating.
    My daughter is desperate to get her pictures off the phone but I'm out of ideas... Any help would be greatly appreciated.
    Thanks, Vix
    05-12-2014 03:41 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery itself might be bad. If you place it flat on a table and are able to spin it freely, that suggests a bulge in the middle, which means battery failure. Try a new battery.
    If there's an external SD card inserted, remove that as well, and try powering on again. A corrupted SD card can cause odd behavior.
    05-12-2014 03:06 PM
  1. Need to go back to 4.1...need help
    By edilee012 in forum HTC EVO 4G LTE
    Last Post: 05-19-2014, 11:19 PM
  2. Help restoring Apps after switching from S2 to S3
    By Rob James3532 in forum General Help and How To
    Last Post: 05-13-2014, 10:08 AM
  3. I need help about my Android!
    By DJShawnz in forum General Help and How To
    Last Post: 05-13-2014, 03:14 AM
  4. How to change Unlock to Lock booloader PLEASE HELP!!!
    By natathaphol in forum HTC One Rooting, ROMs & Hacks
    Last Post: 05-12-2014, 08:59 PM
  5. I'm rooted but i need rom for huawei u8730 t-mobile mytouch q (its 4g if that helps)
    By Will blue in forum myTouch 4G Rooting, ROMs, and Hacks
    Last Post: 05-11-2014, 10:28 PM
