Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Golfdriver97
  • 1 Post By srkmagnus
    swaggypete223's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How common are home screen apps in android?
    Im a new android user after switching over from iOS, where home screen apps are not allowed. Just was curious how many people use apps on their home screen, and if so what are some good/common ones. Also are home screen apps typically used by the every day android user or for more advanced users?
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How common are home screen apps in android?
    Quote Originally Posted by swaggypete223 View Post
    Well, first of all congratz for switching to the Android, and yes in Android home screen can be changed according to your own convenience you can either put your own picture or you could try out some launchers like Buzz launcher, Nova, Next Launcher . With the help of these launcher you can totally customise your device home screen. I almost forget to tell you that these launcher also offers icon packs which can even help you in making your device look like iPhone. But that depends upon you have a look at some launchers I have suggested.
  3. #3
    clemson77on's Avatar
    Posts
    Global Posts
    136 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm assuming that you're referring to widgets. I have the Gmail widget for a fast peak into emails, Google Now widget, Keep widget for a fast glance an notes, and my favorite and most useful widget, Simple Calender.
  4. #4
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,056 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Welcome to the forums.
    If you are referring to widgets, I have 3 on 2 of my homescreens. It really is nice to have something like the weather refreshing itself (I have the interval set to 3 hours).
    I will provide a screen shot in a few minutes.
  5. #5
    Posts
    Global Posts
    33,056 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Screenshot
    From an SOKP Nexus 5
    Attached Thumbnails Attached Thumbnails How common are home screen apps in android?-1399989459808.jpg
    srkmagnus likes this.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    I would recommend keeping anything that you feel you need quick access to. If knowing the weather is important, then use a weather widget - be sure to keep the refresh interval conservative to save battery. There are tons (Music player widgets, text messaging widgets, email widgets, etc.) with a lot of customization available to the user. Let us know what you do most often with the device and we'll try to recommend widgets you may like.
    Also, note the folders in Golfdriver's screenshot above. Use folders to keep stuff organized. This is no different than having a folder in iOS. Let us know if you have any questions.
    Golfdriver97 likes this.
  7. #7
    STARGATE's Avatar
    Posts
    Global Posts
    9,257 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Welcome to Android and to the AC forums! 🙋
    What device did you get?
    And I agree with the post below.
    Quote Originally Posted by srkmagnus View Post
    Sent From Inside The TARDIS in a Galaxy S4 Away!
  1. Android Game Publish Master
    By Nayem Islam1 in forum Android Games
    Last Post: 02-21-2015, 10:26 PM
  2. Pictures from Internet take a couple seconds to fully load in
    By Jon Jackson in forum Samsung Galaxy S5
    Last Post: 05-15-2014, 08:28 PM
  3. why are some Verizon Galaxy Note 3 phones manufactured in Korea instead of China?
    By CarrierPigeon in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-14-2014, 10:06 AM
  4. Galaxy S5: Phone Contact and Wallpaper/Lock Screen Pic Sizes
    By hwldknights in forum Samsung Galaxy S5
    Last Post: 05-13-2014, 05:19 PM
  5. How do you add lock screen widgets?
    By jd914 in forum HTC One M8
    Last Post: 05-13-2014, 12:08 AM
