Hello
I have a Samsung Galaxy Tab 7, P1000. I gave it to my brother and he was using it for some time and upgraded android 4.0.x
Some of the functionality was not working. I thought I will upgrade to KitKat
After googling found solution here
How to update Samsung galaxy tab GT-P1000 to Android Kitkat 4.4.2 CM 11 Step by Step - HYGO ANDROID
I have used Gingerbrid 2.3.x
and PIT file suggestion
Using Odin3 V1.7 uploaded the files successfully
Upon rebooting, I tried to Wipe chche, it is working successfully
When I tried Wipe data/Factory Reset I get the following message
E:format_volume: rfs format failed on /dev/block/stl10
What does this error mean? How do I resolve?
Thank you and appreciate your help
