Results 1 to 3 of 3
    PlsHalp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Stuck at HBOOT screen controls don't work
    My phone got a fair bit of water in it and after drying out, it powers up to the HBOOT screen but vol up/down do not work nor does any other button. Curiously enough the phone seems to recognize if I insert the usb plug but my computer says failed to recognize device/load drivers.
    This is what the screen says:
    INCREDIBLEC XC SHIP S-ON
    HBOOT-0.92.0000
    MI CROP-0417
    TOUCH PANEL-ATMEL224_16ab
    RADIO-2.15.10.07.07
    Jul 23 2010, 18:06:51
    HBOOT or if USB in HBOOT USB PLUG
    <VOL UP> TO to previous item
    <VOL DOWN> to next item
    <POWER> to select item
    FASTBOOT
    RECOVERY
    CLEAR STORAGE
    SIMLOCK
    FACTORY RESET
    I'm not too familiar with the whole technical language of this stuff so try to keep it simple. Any help would be appreciated, thanks.
  2. #2
    raichur0xx0rz's Avatar
    Posts
    Global Posts
    380 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Stuck at HBOOT screen controls don't work
    Quote Originally Posted by PlsHalp View Post
    HBOOT-0.92.0000
    MI CROP-0417
    RADIO-2.15.10.07.07
    FASTBOOT
    RECOVERY
    CLEAR STORAGE
    SIMLOCK
    FACTORY RESET
    You mentioned the Vol. buttons, and other buttons, so I assume that includes the Power button? Did the power button work when it was turned off?
    PlsHalp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, the power button is how I get the screen to come up, but the only way to get the phone to turn off is to pull the battery.
  1. Google play not working
    By PainFX in forum Samsung Galaxy S5
    Last Post: 09-21-2014, 10:08 PM
  2. At&t Power Saving Mode Coming this week?
    By Lilshaq65 in forum HTC One M8
    Last Post: 05-14-2014, 03:39 PM
  3. visual voicemail set up now works
    By russel5150 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-14-2014, 12:30 AM
