Results 1 to 2 of 2
    N7AS's Avatar
    Posts
    Global Posts
    46 Global Posts
    Default Can't see SD Card in computer - LG Optimus F6
    I have an LG Optimus F6 with MetroPCS. I have installed a 32GC MicroSD in the phone. I can move apps to the sd card ok using Apps 2 SD. When I look at the phone on my computer, the only thing that shows up is the phone's Internal Storage but not the SD card. I know the phone recognzses the card as when I go into Settings > Storage, it shows the card storage as 29.31MB and Available 29.26GB.
    How do I get the computer to see the SD Card?
  2. #2
    Default Re: Can't see SD Card in computer - LG Optimus F6
    Quote Originally Posted by N7AS View Post
    Just plug it into the SD card reader, you usually get a free USB one with SD card.
    I gave up on phone managers and waiting for the SD card to show up.
  1. LG G2 remote shutter control for camera
    By ginglish in forum Sprint LG G2
    Last Post: 10-25-2014, 09:57 PM
  2. Replies: 7
    Last Post: 05-19-2014, 03:04 AM
  3. Can't Sync Contacts
    By baileyhewes in forum General Help and How To
    Last Post: 05-15-2014, 11:20 PM
  4. White dot in top speaker's hole.
    By U WOT M8 in forum HTC One M8
    Last Post: 05-15-2014, 09:19 PM
  5. Error in internal memory. Restarting
    By Dulanjana Perera in forum Samsung Galaxy Tab 7-inch
    Last Post: 05-15-2014, 11:59 AM
