1. AndroidHTC2013's Avatar
    How do I downgrade my HTC One back to 4.1.2? I already have my phone rooted but I don't know how to downgrade it
    05-16-2014 05:03 PM
  2. srkmagnus's Avatar
    You should be able to flash a ROM that is based on 4.1.2. Otherwise, you will need to find the appropriate ROM Utility Update (RUU) for your model HTC One (be sure it's specific to your model) and use that to restore back. That will get you unrooted, back to stock and on 4.1.2.
    By the way, which HTC One do you have (M7/M8 and carrier)?
    05-16-2014 07:08 PM
  3. AndroidHTC2013's Avatar
    I have the M7 from AT&T. I can't really find a ROM that says it's built for the HTC One, any website that I try finding says its only there to like customize 4.1.2 only if it's already there. Could you perhaps give me a link? Also is it possible to keep 4.4.2's keyboard along with its emojis? This is the only thing that I would like to be saved if it's at all possible.
    05-16-2014 10:10 PM
  4. srkmagnus's Avatar
    Check XDA-Developers. That's where you are going to find the RUU or stock ROM for your device.
    AndroidHTC2013 likes this.
    05-17-2014 08:58 AM
  5. AndroidHTC2013's Avatar
    Okay I'm in big trouble now I was able to finally a 4.1.2 rom but when I flashed it the touch screen wouldn't do anything. The power and volume buttons were the only functional left. And then I did a few adjustments while in TWRP but that got me stuck in there since now I don't have a OS program running for some reason. HELP! I would really appreciate the help srkmagnus
    Who would have thought rooting and flashing ROMs would be this difficult.
    05-17-2014 07:59 PM
  6. AndroidHTC2013's Avatar
    Can somebody help me out here!?!?!? This is so frustrating!!
    05-18-2014 06:41 PM
  7. Rukbat's Avatar
    There's a saying - when you find yourself stuck in a hole, the first thing to do is stop digging. The more you do, the worse you're going to make the situation.
    Bring the phone to the carrier's store, ask if they do repairs there, or where they have a store that does repairs, and pay to have the phone fixed. Or, if the estimate is more than the phone is worth, buy a new one. And don't try playing with it until you learn more.
    05-18-2014 11:36 PM
  1. Overheating since Sense 6 update on M7
    By neo905 in forum HTC One M7
    Last Post: 07-30-2014, 04:03 AM
  2. Auto Correct & Suggestion on HTC One (M7)
    By Warluck in forum HTC One M7
    Last Post: 05-20-2014, 03:57 PM
  3. Crazy battery life on Galaxy S4
    By Yousef Amarneh in forum Samsung Galaxy S4
    Last Post: 05-19-2014, 05:07 PM
  4. Can see photos on camera but not open on computer
    By Jeff Blagg in forum Samsung Galaxy S5
    Last Post: 05-19-2014, 01:05 AM
  5. Replies: 3
    Last Post: 05-18-2014, 12:10 AM
