Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By Aquila
  • 1 Post By dpham00
    Default Samsung Galaxy Tab 2 10.1 New Charger Problem!
    I'd tried using the new charger in the Philippines but when i used it and i pulled up my tablet with my charger in 2 times and it badly damaged the inside of the new charger and i don't know what to do please help me?
  2. Thread Author  Thread Author    #2
    Default Re: Samsung Galaxy Tab 2 10.1 New Charger Problem!
    Please help?
  3. #3
    Welcome to Android Central! It's not entirely clear what you're trying to say. Do you mean the charging port of your tablet is damaged? Or is the tablet malfunctioning after using the charger? Is it an official Samsung charger, or a 3rd party one you bought elsewhere?
    Default
    I think it's an official Samsung Charger please help?
    But the inside of the charger wire are broken
  5. #5
    You could buy a new charger. It doesn't have to be from Samsung. Any micro USB cable should work.
    Posted via Android Central App--please excuse the brevity and any typos!
    If i use the 3rd party one what will i do?
    Default
    Please help me?
  8. #8
    MicroUSB cables are essentially standardized, so you can use any microUSB cable to plug into your tablet. The charging block itself can vary in terms of amperage, but for the most part, the tablet will be smart enough not to overcharge. So use any microUSB cable/charger that you might have for any other device, or buy one from your local electronics store.
    Quote Originally Posted by B. Diddy View Post
    Is it the same with Samsung charger?
  10. #10
    What I'm saying is that any microUSB charger should work fine.
  11. #11
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,718 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
  12. #12
    Aquila's Avatar
    Gonfaloniere
    Posts
    Global Posts
    13,560 Global Posts
    Carrier
    Assassin 'Droid
    Quote Originally Posted by Golfdriver97 View Post
    Or THIS!!!!! Andru 1A USB Charger - Android Chargers & Cables I love Andru, I have three of them
    Golfdriver97 likes this.
  13. #13
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    A good quality charger shouldn't cost more than about US$5. Check eBay. (Chargers are pretty much commodities today, the only differences being whether the cable is attached or plugs into the charger, and how much current the charger can supply. Since almost no phone can draw more than about 1.2 Amperes, a 1 Ampere charger should be fine for any phone. If the phone can draw 1.2 Amperes, a 1 Ampere charger will take about 20% longer to charge it. But even 2 Ampere chargers aren't much more expensive.)
  14. Thread Author  Thread Author    #14
    I think I'd used it before you the new charger but i think it's expensive
  15. Thread Author  Thread Author    #15
    Help me find an a non expensive charger?
  16. #16
    Posts
    Global Posts
    32,718 Global Posts
    Carrier
    Quote Originally Posted by Jellal View Post
    Keep in mind, what you pay reflects the quality of the product: Travel Charger For Samsung Galaxy Tab, Tab 2, Galaxy Note 10.1 - Samsung Galaxy Note 10.1
  17. #17
    Also keep in mind a low quality charger can damage the device, and in rare instances can cause injury or death.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  18. Thread Author  Thread Author    #18
    Quote Originally Posted by dpham00 View Post
    If the charger is high quality cannot be damage the device right?
  1. Crazy battery life on Galaxy S4
    By Yousef Amarneh in forum Samsung Galaxy S4
    Last Post: 05-19-2014, 06:07 PM
  2. Replies: 5
    Last Post: 05-19-2014, 07:58 AM
  3. Replies: 3
    Last Post: 05-18-2014, 01:10 AM
  4. Forgotten unlock pin on Galaxy S3
    By txfarmboy in forum Sprint Galaxy S3
    Last Post: 05-18-2014, 12:13 AM
  5. GPS Dead since Samsung re-flashed ?
    By bigandroidfan in forum Samsung Galaxy Note 10.1
    Last Post: 05-16-2014, 05:19 PM
