Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By Rukbat
    Default How to root Chinese galaxy note 19220
    I'm having a problem trying to initiate the root process. There is no developer option. Can I still root the phone? What software should I use? Or can I use Odin?
    Sent from my Galaxy Nexus using AC Forums mobile app
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: How to root Chinese galaxy note 19220
    Press the build number (in the phone info) about 7 times and you'll get the developer menu - which has nothing to do with rooting.
    How do you root the phone? If it's a real Note, use Kingo. If it's a "Chinese clone" (IOW, the only thing "Note" about it is the label, the name on the case, etc.), your guess is as good as mine, since neither of us knows what phone it actually is. (Some Chinese manufacturers are coming out with phones with the Samsung name on the case, real-looking labels under the battery - which claims to be a Samsung battery, but the phone is as much the Samsung phone it claims to be as a 1957 Chevy is a 2014 Ferrari. You pay a lot less for the phone, but it's not worth as much as you pay for it.)
    UJ95x and icewater106 like this.
    There isn't a build number in the settings. I always thought USB debugging had to be enabled so you can root the phone. I have a galaxy nexus and it always says to enable USB debugging. Yea its a clone. It claims its on android 4.2.1 but the os is gingerbread.
  1. Galaxy S5 Waterproof Backdoor Covers
    By smooth4lyfe in forum Samsung Galaxy S5 Accessories
    Last Post: 05-23-2014, 11:41 PM
  2. Samsung galaxy s5 need heeelllllpppp!!! Please
    By castrolos67773 in forum Samsung Galaxy S5
    Last Post: 05-19-2014, 12:35 PM
  3. Help Needed! Phones to consider & phones to avoid!
    By tess1977 in forum General Help and How To
    Last Post: 05-19-2014, 11:00 AM
  4. Help Needed! Phones to get & Phones to avoid!
    By tess1977 in forum Samsung Galaxy S5
  5. Nexus 5 to EH5300 Screen Mirroring Problem
    By hell911 in forum Google Nexus 5
    Last Post: 05-18-2014, 08:57 PM
