1. moviedude2k's Avatar
    Hello, I recently bought the elusive Z1 compact- it's about time I found a phone that is sub-5 inch and a powerhouse. But anyways, I have never owned a phone with on screen buttons before (coming from Galaxy S series) and I was curious if the on screen buttons for "back", "home" , or "menu/app launcher" be re organized? A friend of mine has a LG g2 and they can reorganize theirs and I was wondering if that was an android feature or just LG. I would love to get my "back" button on the right side of the phone , if this is possible. Thanks!
    05-19-2014 09:44 AM
  2. dancing-bass's Avatar
    LG is the only one that allows this for a stock (unrooted) device. Even with root, I'm not sure if it's possible, although it may be - I haven't looked into the ROMs available for the Z1 compact. But stock? no - not possible to the best of my knowledge.
  3. dancing-bass's Avatar
    05-19-2014 09:55 AM
  4. Golfdriver97's Avatar
    You would have to root and install Xposed Framework, with a Gravity box module.
    05-19-2014 10:03 AM
  1. Daily multiple freezes with S5 on AT&T
    By Bambii68 in forum Samsung Galaxy S5
    Last Post: 06-08-2014, 10:03 PM
  2. Gear 2 vs Neo = Why did you decide on which one to buy.
    By kh4fun in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-26-2014, 08:29 PM
  3. Help! Deleted OS on Galaxy Nexus
    By David Wong 123 in forum Samsung Galaxy Nexus Rooting, ROMs, & Hacks
    Last Post: 05-19-2014, 01:27 PM
  4. How to get daily forecast to appear on 4x1 HTC calendar widget?
    By RockyMtnRedRaider in forum HTC One M8
    Last Post: 05-19-2014, 10:56 AM
