Results 1 to 7 of 7
    Default So I can only block unwanted calls for 90 days ?
    I have a LGG2 smart phone and I'm getting unwanted calls. So I logged into my Verizon online account and I can block calls but only for 90 days and only up to five phone numbers. If I want to block any longer or more numbers I have to upgrade my plan. I would have thought within the phone settings I would have more options to block incoming calls but guess not. This it so dumb, do I have any alternatives ? thanks
  2. #2
    Default Re: So I can only block unwanted calls for 90 days ?
    Quote Originally Posted by Scott111 View Post
    Have you tried this?
    LG G2 User Guide
    (not a smart *** post, the link takes you to the page you need )
    Sorry I should have mentioned I'm using Verizon as my carrier, I don't have call reject settings.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Here is an App I found on the Play Store, hopefully it's what you are looking for: https://play.google.com/store/apps/d....easyblacklist
  5. #5
    Hi,
    I tried many apps to blocking unwanted incoming calls.
    I think the easiest to use is StopContacts. There is a lite version https://play.google.com/store/apps/d....callblocklite and a pro version https://play.google.com/store/apps/d...ndst.callblock
    The pro version has an option that active the call blocker service at certain time, based on your time settings
  6. #6
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Verizon is trying to make money off of your problems. So your carrier/provider is a scavenger.
    The free app "Mr. Number-Block calls, texts" solves all your problems.
    ok thanks
  1. Otterbox for tab Pro 8.4
    By Userp222 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 06-11-2014, 06:29 PM
  2. App for ringtones and notifications
    By alil25 in forum Samsung Galaxy S5
    Last Post: 05-20-2014, 08:36 AM
  3. Different sound for Text Messages vs. Other Notifications
    By jaihawk in forum Samsung Galaxy S5
    Last Post: 05-19-2014, 04:12 PM
