Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By UJ95x
  • 1 Post By srkmagnus
    Default delete texts
    Still learning on Samsung Galaxy Ring; how can I delete all texts in a thread rather than just delete one at a time? I played around with touch, slide, etc. with no luck.
  2. #2
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Default Re: delete texts
    Quote Originally Posted by jamak View Post
    Still learning on Samsung Galaxy Ring; how can I delete all texts in a thread rather than just delete one at a time?.
    That can vary by app. So what app are you talking about?
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    For a couple of the apps I have used, it's tapping and holding on the specific thread. Then you'll have the option to delete it
    Sent from my Galaxy S4 running SlimKat 4.4.2
    srkmagnus likes this.
    I'm using Messenger. I press a text and app has delete and a few other commands but will only delete that one text. If I tap a few times, that one text just fills the screen.
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Did you try the solution posted by UJ95x? Long press the thread (conversation) and select the delete option.
    UJ95x likes this.
  6. #6
    When you're within the thread, what happens when you tap the menu button? Is there a Delete option? Does that delete the whole thread?
    Yes, it says copy msg/copy msg text/lock msg/forward/view msg details. But I can only delete 1 msg at a time rather than a group.
    NOTE: I figured it out, there's a trashcan on top right side, I press it and it has a Select All check and will delete thread.
    thanks
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    thanks
    Glad you got it fixed
    See you around the forums.
  1. Replies: 30
    Last Post: 05-30-2016, 09:24 PM
  2. Deleted default camera folder
    By galpal00 in forum AT&T Galaxy S3
    Last Post: 05-21-2014, 09:24 AM
  3. Different sound for Text Messages vs. Other Notifications
    By jaihawk in forum Samsung Galaxy S5
    Last Post: 05-19-2014, 04:12 PM
  4. Help! Deleted OS on Galaxy Nexus
    By David Wong 123 in forum Samsung Galaxy Nexus Rooting, ROMs, & Hacks
    Last Post: 05-19-2014, 02:27 PM
  5. GIFs won't play in text
    By oldrtyfrog in forum HTC EVO 4G LTE
    Last Post: 05-19-2014, 10:32 AM
