1. Junaid Awan's Avatar
    I have searched the forum but could not find help. Please give me link if there is some other thread addressing same issue.
    My problem is that when I install any app from google play, it installs on internal storage. If I want to move it to sd card, the only option available is move to phone storage. I have selected SD Card as default write disk. The attached pics show all relevant details.
    05-21-2014 10:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I would guess that your phone's onboard storage is partitioned into two areas--one for app installation (usually called App Storage) and one for general data storage (variably called Internal SD or Internal Storage). This doesn't count the physical SD card, which is usually called External SD. When moving an app to SD, the SD in question is usually the INTERNAL SD, not the external.
    So in your case, your Phone Storage and Internal Storage probably represent App Storage and Internal SD (although it might be vice versa). You usually can't move an app to the external SD.
    See this guide for more info: http://forums.androidcentral.com/amb...-warnings.html
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    Junaid Awan likes this.
    05-21-2014 03:03 PM
  3. Junaid Awan's Avatar
    You understood exactly what I asked but I needed an answer to the following question:
    How can I solve the problem?
    I went to the warranty shop, they solved the problem but erased every thing. They told me that there is a file in OS which solves the problem. Later on another occasion my phone got OS reinstalled due to freezing problem. Now the apps problem has come again.. I dont want to erase all data and get OS installed again. I know that will solve the problem but that is a time consuming process..
    05-22-2014 05:19 AM
  1. Replies: 35
    Last Post: 05-26-2014, 09:40 AM
  2. Contacts Storage Using more bandwidth
    By sajingeorge in forum HTC One M8
    Last Post: 05-21-2014, 09:13 AM
  3. Prevent responding to text pop-up over lock screen
    By tomstinson in forum HTC One M8
    Last Post: 05-21-2014, 08:56 AM
  4. Something happened to my Optimus One
    By asdjklghty in forum LG Optimus Series
    Last Post: 05-21-2014, 08:37 AM
  5. notes3 splanner to s5
    By Cocoaflavor in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 05-21-2014, 08:31 AM
