1. Jellal's Avatar
    Hi, how long it will take to charge an Android Tablet?
    05-22-2014 11:07 PM
  2. Rukbat's Avatar
    As Kelly said, "it depends". On how discharged the battery is (you shouldn't let it get below 40% if you want it to last as long as possible), what the temperature is, how much current the charger can supply (and how much the tab is designed to draw), the condition of the battery. There's no single answer, even for a new tab of a certain model for the first full charge from 40% after it's been conditioned. Different batteries will take different times. It's like asking how much food will stop a person's hunger.
  3. Kelly Burby's Avatar
    Well, I would say it depends usually it takes around 7-8 hrs to completely charge.
    Jellal likes this.
    05-23-2014 12:30 AM
  4. neonworm's Avatar
    Which Android tablet? There are a lot.
    05-23-2014 12:44 AM
  5. Jellal's Avatar
    Samsung Galaxy Tab 2 10.1 (Android)
    05-23-2014 05:12 AM
  6. Rukbat's Avatar
    B. Diddy likes this.
    05-23-2014 11:57 PM
  1. Galaxy S5 announcing who's calling has stopped working, now to restore
    By Falconeer Taylor in forum Samsung Galaxy S5
    Last Post: 10-05-2014, 08:49 AM
  2. What's the best way to clean up your internal storage?
    By Lyle DylandY in forum General Help and How To
    Last Post: 09-22-2014, 10:28 AM
  3. Browser after KitKat update (Acer tablet)
    By Unregistered in forum Ask a Question
    Last Post: 09-21-2014, 03:04 PM
  4. How to Disable new kitkat 'fade in' in the homescreen
    By Johnny Ovadias in forum Ask a Question
    Last Post: 09-20-2014, 07:45 PM
  5. Should I encrypt my GNP 12.2 and how? Risks?
    By lmb02 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 09-20-2014, 05:56 PM
