01-15-2017 03:06 AM
27 12
tools
  1. Anders Mansfeldt's Avatar
    Hi.
    The 'find my android' at device manager does not work. I have an gmail acconunt, i have activated location reporting, it is turned on and connected to wifi and the mobile service, and it' lying on the table in front of me. still it's not shown on the map, and nothing happens when i press 'call button' (on the map). What is wrong/ missed in the settings?
    Please help!
    Edit: I'm using a samsung S5
    05-23-2014 06:08 AM
  2. davidnc's Avatar
    Hi.
    Please help!
    So I assume you have it ticked under the device administrators settings as well ?
    05-23-2014 06:52 AM
  3. Kelly Burby's Avatar
    Hi.
    Please help!
    Well, I am experiencing the same thing yesterday but now it seems to be working fine. I'll say that try checking the same again It should be working fine now !!
    05-23-2014 06:59 AM
  4. Anders Mansfeldt's Avatar
    Where/how do I do that?
    05-23-2014 08:07 AM
  5. Anders Mansfeldt's Avatar
    Maybe it's so. I asked my brother to check his, and it did not work either. I'll check it later.
    05-23-2014 08:11 AM
  6. davidnc's Avatar
    Settings>Security>Device administrators> the option should be ticked.
    I tried mine out at 7:50 am ,it worked on my device.That was right before I posted earlier.
    05-23-2014 11:57 AM
  7. Anders Mansfeldt's Avatar
    It still does NOT find my phone. It works when I log into device manager from the phone's internet, but no when I do so from the computer.
    05-26-2014 06:02 AM
  8. Jellal's Avatar
    Hi.
    Please help!
    Hi, you can go to your settings and go to your security if you have, hope it works.
    05-26-2014 06:38 AM
  9. makaka's Avatar
    Go to Google settings app (note it is different from just Settings which is for the itself). Find Android device manager and check remote locate and remote lock & erase if you wish. In Google settings get to Location and check location access. By now you should be set. Go to www.android.com/devicemanager and sign in. Wait for a while Google finds your phone(s).
    And note that if your phone goes to sleep, it usually takes longer to connect to it and locate (10-15 min).
    05-26-2014 07:03 AM
  10. Anders Mansfeldt's Avatar
    I'm very sorry to say so, but no: Still not there. I waited for abut 20 minutes, and it doesn't work. It does work from the phone, but not from a computer...
    05-26-2014 04:25 PM
  11. Vsweety's Avatar
    Do other tracker apps, like (free) Glympse, work in your set-up?
    05-26-2014 10:42 PM
  12. makaka's Avatar
    Or try Airdroid which a nice phone management suite including locator.
    05-27-2014 02:21 AM
  13. shelquis's Avatar
    Hi Anders. Like you, Android Device Manager won't do anything from the pc, while it seems to work normally from the phone itself. I don't see any answers to your (our) problem in the replies, but I wondered if you have found the solution? Please post it if so. If not, I'll stay subscribed to this topic in hopes somebody knows how to get Device Manager to work from the pc like it does from the phone.
    05-30-2014 11:58 AM
  14. Anders Mansfeldt's Avatar
    I can find my phone loging on from both my brother and fathers phone, hence the problem must lay in the computer.
    But the problem is not realy a problem, since I can use one of their phones if I need to find mine.
    I have no clue what the problem in the computer might be.
    05-30-2014 05:30 PM
  15. shelquis's Avatar
    Thanks for the quick reply Anders. Since I don't have a brother or father whose phone I can use, please leave your thread unanswered. Hopefully someone with the appropriate knowledge will reply with suggestions that will solve the problem.
    05-30-2014 06:55 PM
  16. Labradorite's Avatar
    I had the same problem.
    It turned out to be one of those embarrassing moments when I realized the problem.
    I too tried all the items posted by others here and elsewhere.
    When I finally read everything on the Android Device Manager Help screen I realized my problem.
    I use my PC to install apps from play. I just find it so much faster and easier to see. Problem was every time I would attempt to install an app on my tablet from there the phone would be the first thing to show up. It got annoying so I went to see if there was a way to change the default device.
    Didn't find that but did find a way to hide the device. That was my problem.
    Here is the last paragraph:
    Devices that are hidden on Google Play
    If you hide a device on Google Play, the device won’t appear in Android Device Manager. You can hide or show devices on Google Play by going to play.google.com/settings and selecting a device in the Visibility column.
    I hope this helps.
    01-02-2015 06:42 PM
  17. Guilly's Avatar
    I had the same problem until I realized that I was using Juice Defender.
    Maybe you are as well using other apps that make the battery lasts longer but disable many of the phones features when the screen is off such as the MOBILE NETWORKS and GPS.
    After I uninstalled it, everything worked smoothly
    Hope it helps
    02-18-2015 04:57 PM
  18. richgupta's Avatar
    Yes your suggestions helped... play.google.com/settings
    08-15-2015 05:18 PM
  19. Bernie Silberstein's Avatar
    I have an S5 and Android manager is able to locate my phone from a computer when the phone WIFI is on and connected to the internet. If I switch the wifi off (but still have internet access via my 3G network) then I can't locate the phone. Any suggestions?
    11-13-2015 09:36 PM
  20. dandb's Avatar
    I had a problem where it appeared Find My Phone was working, it would say Ringing, but I wouldn't hear anything on my phone. Turns out I had Notification Volume turned down. It can be turned back up with Volume button / settings gear / Notifications slider - duh.
    01-25-2016 04:58 PM
  21. Tom Mikels's Avatar
    I have a samsung galaxy note 5. Device manager will not find my phone from my laptop. What is weird when i go to locate, on my phone it says device manager has located my phone but on the laptop it says it can not find it. Also when i try to ring the phone , the phone will make a little tick sound. I hope someone can help me.
    01-27-2016 05:35 PM
  22. Gremlin256's Avatar
    I own a LG G3 and I live in Cali.. Android device manager, nor Google Play store/settings does not see my LG G3 in the list. Looking in the phone, it says my phone was activated in memphis?? WHat do I do?
    02-12-2016 09:27 PM
  23. DasOneGuyYah's Avatar
    Had the same problem before except it would accept a "find" command from my laptop when my screen was unlocked. I found out that in a recent update, Samsung put application/battery optimization on as default. This will stop most functions from completing tasks when the screen locks in order to save battery and RAM resources. How to fix would be to go into your battery settings, hit optimization and then turn app optimization off. It worked after that for me.
    02-18-2016 12:40 AM
  24. Eric Jackson505's Avatar
    It would be nice if Google mentioned somewhere that the Ring My Device command won't override notifications being on silent. They just say it will ring your phone "at full volume." No, it won't. Grrrr.... >
    02-20-2016 06:27 PM
  25. thiyagups's Avatar
    thankyou ......i checked in to show the devices in Google play setting and its now appearing in android device manager
    03-03-2016 12:29 AM
27 12
  1. Is my phone dead FOREVER !!!
    By missteeone in forum Samsung Galaxy Note 2
    Last Post: 05-23-2014, 07:52 AM
