Hi Everyone, I think I can save the day here for all of us! Im no tech savy verizon genius, but apparently im smarter than all of them..
so this problem got me thinkn its a memory issue due to the fact that it doesn't delay right when u get the phone, it takes a month or two. Its like the phone slows down the more you use it. Its actually just like ur computer, it slows down cuz the browser collects lil data, cookies, each website u go to, without u knowing it, it builds up over time, and slows cuz of memory loss. So I figured, what the hell, its just like a comp, we use the browser, so I searched around for where the memory storage is monitored...this is what I did:
(1) go to settings (2) go to applications (3) manage applications (4) running applications this shows u allll the stuff that's currently running, kid of like the task manager on ur computer (5) go thru and find browser (6) select it and scroll down to cache, it will most likely show u alot of memory, then clear it by hitting clear cache..it will then read as '0.00B' (7) go thru everything and clear all caches that have anything but zero, and u can even uninstall things u don't use that eat up memory, but donnnt delete anything if u don't know what it is! And u can also 'force stop' programs u don't use too (8) once your finished, shutdown, remove battery, remove sd card, wait thirty seconds, put it all back, and restart (9) go directly to text messaging and send a cooperative friend a text, but put the time in parenthesis at the end, and see if they get it right away, then have them reply putting the time at the end of theirs too. Once you send a few and realize its on time,,,PROBLEM SOLVED! !!!
take that verizon, it took a bio major single mom to figure this out before ur geek squad! Lol!
I did this an hour ago..seems to have worked, but it may only be short term fix, but im just gonna keep clearing my cached items every so often, and I should be allset!
Hope I could help u guys!!! It was driving me insane too! If u want, u can always send me a happy donation to express ur thanks
With lots of smarts and genius
J2Bean212
J2Bean212
