Results 1 to 2 of 2
    erincox2010's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy Tab 3 7 inch Sd Card Adapter
    Hi, I'm looking for an adapter for a Samsung Galaxy Tab 3 7 inch. I need something that will allow me to read a standard SD card, I've found one on eBay ( Micro USB HUB Micro SD Card Reader Adapter OTG Cable 4 Samsung Galaxy TAB 3 S4 | eBay ) but I don't think the 7 inch tab supports the OTG function??
  2. #2
    AndroidProf's Avatar
    Posts
    Global Posts
    308 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Galaxy Tab 3 7 inch Sd Card Adapter
    Quote Originally Posted by erincox2010 View Post
    Yeah the OTG does not support the OTG function, so buying the cable will not be that helpful. I am not sure there's a USB adapter that doesn't use OTG...because that's what you should be looking for for this to work. You could use a PC?
