1. kevinsun91's Avatar
    Hi!
    All new contacts I save goes to my sims card.How can I change the setting so all my contacts will be saved to my Google account? Thanks!
    05-25-2014 11:12 AM
  2. AndroidProf's Avatar
    Open your phonebook or "Contacts" and tap the Settings button (if you're using Samsung or just the drop down Settings menu (on other OEMs) , Once in settings, you will see "Save new numbers to" just tap that and change that to your Google account. I'm sorry I can't really provide step by step guide as you haven't really told what phone you're using or specifically what version fo Android you're device is on
    05-25-2014 10:42 PM
  3. kevinsun91's Avatar
    Oh sorry. I have a Samsung Galaxy S3. When I open my contacts and go to settings, I see the following options
    "Only contacts with phones"
    "List by"
    "Display contacts by"
    "Service numbers"
    "Contact Sharing Settings."
    I don't have a "Save new numbers to."
    I'm not sure how to check what version of Android my phone is running.
    05-26-2014 11:40 AM
  4. Vsweety's Avatar
    On your home screen, go into Settings, scroll down to the bottom, tap on 'About device'
    05-26-2014 05:55 PM
  1. How to Force Roam
    By truenoboy in forum Samsung Galaxy S5
    Last Post: 06-12-2014, 01:36 PM
  2. How to move pictures to SD Card on LG L70?
    By blocts in forum General Help and How To
    Last Post: 05-25-2014, 11:16 AM
  3. Phone says its done charging, when I take it out it goes down to about 40%
    By chunkymonkey1212 in forum General Help and How To
    Last Post: 05-25-2014, 11:07 AM
  4. downloading software taking over 12 hours to update
    By srjaide in forum AT&T Samsung Galaxy Note 3
    Last Post: 05-25-2014, 09:52 AM
