Since updating to Froyo on my Droid X, I've noticed my camera's autofocus won't work at all. I first noticed this because the barcode scanner can't read bar codes anymore because they are too blurry. I want to try a factory wipe to see if that fixes it. I just did a factory wipe 2 weeks ago and it erased all of my applications and settings and was a huge pain to reinstall everything. Is there a way to backup these apps, so I can just automatically re-download them after I do the wipe? Thanks for any help.
