Results 1 to 8 of 8
    Default Where can I get the Tango Messenger ringtone and notification tones..
    Hi, I have a GT-S5830 running on 2.3.3 (no ROM). I recently downloaded Tango Messenger and it's great! Whenever I receive a message or a video call, it makes the sounds that I like. I wanted to know where I can get a link of the ringtone and the notification tone so I can put it as my ringtone and SMS. Thank you very much.
  2. #2
    Default Re: Where can I get the Tango Messenger ringtone and notification tones..
    You could try downloading the Zedge app. They have bookoodles of sounds for downloading. It might be available there.
    Notes from Deb's Note 3
    I looked on SoundCloud and Zedge, but it came up with weird Mexican/Spanish music. Bad luck for me.
    I got the ringtone, but I'm trying to find the notification tone. Any help?
  5. #5
    I'm wondering if you can't copy them from the app folder to your ringtone and notification folders by plugging it into your computer, locating the files and just copying it over? I'm pretty sure I've done this before.
    If you and a friend that have this tango thing you might also try the S beam.
    No, you can't. Because I checked my files and I couldn't find Tango. And I have a friend who uses Tango, but I don't have S Beam or NFC and they also don't have it.
  7. #7
    Can you provide me the link for Tango messenger ringtone download
  8. #8
    Hi.... I need to know...how can i changed my ringtone for Tango Massanger....
  1. dual sim: how to disable completely data for the second sim
    By Marco Smotckins in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-22-2016, 11:48 AM
  2. How to get rid of auto dialing feature?
    By Sarah Swagger in forum Samsung Galaxy S5
    Last Post: 07-26-2015, 04:18 AM
  3. Verizon Galaxy Note 2: life 360. how do i disable and maybe delete?
    By snowwy66 in forum Verizon Galaxy Note 2
    Last Post: 05-30-2015, 04:50 PM
  4. Dual SIM: can't tether with sim1 if sim2 is present
    Last Post: 03-02-2015, 02:49 PM
  5. Tapatalk app and Android forum's app doesn't accept my password
    By Closingracer in forum Android Central Apps
    Last Post: 09-04-2014, 01:50 AM
