Results 1 to 4 of 4
    Default Screen calibration
    Is there any root app or xposed module that can allow you to tweak the saturation or contrast of your display? I'm talking on the software side not the hardware side
  2. #2
    Vsweety's Avatar
    Banned
    Posts
    Global Posts
    414 Global Posts
    Default Re: Screen calibration
    Quote Originally Posted by Josh Meade1 View Post
    Idk.
    I do know there are these apps.
    Of course the hardware limitations are cast iron.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Yes, there are. That requires root and possibly a custom Kernel to support the feature.
  4. #4
    Hi Josh,
    One app I can recommend is SpyderGallery. It will only work with a Spyder calibration tool and has a crappy design but works correctly.
    Once you calibrate you can view the images in your Photo Roll with reliable colors.
    Unfortunately this won't work outside this app, given that Android hasn't got a flexible color management.
  1. My HTC sensation not on or off just black screen
    By Abid Hussain3 in forum HTC Sensation XL
    Last Post: 08-08-2014, 03:04 PM
  2. Annoying screen message won't go away
    By Joe Mullens in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-29-2014, 07:29 AM
  3. Replies: 1
    Last Post: 05-26-2014, 08:11 PM
  4. Dial screen in landscape?
    By LimuHead in forum Samsung Galaxy Note 3
    Last Post: 05-26-2014, 04:59 PM
  5. Moto G: text message preview on lock screen
    By pow7129 in forum Moto G (2013)
    Last Post: 05-26-2014, 02:22 PM
