Results 1 to 5 of 5
    Default Help with Galaxy S4
    Hi everybody, my galaxy s4 has recently started refusing to download apps. I can click install, the screen will stay "installing" but it never gets to the downloading percentage and nothing ever actually downloads. What should I do?
    Thanks in advance
  2. #2
    Default Re: Help with Galaxy S4
    Welcome to Android Central! Is this on both wifi and mobile data? Try booting into recovery and wiping the cache partition: Reset: Samsung Galaxy S 4 | T-Mobile Support
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by theSTRIKER View Post
    Thanks in advance
    Are you on Wi-Fi or mobile data? Does it happen on both?
    Some quick ideas to fix: 1. reboot the device. 2. log out of your Google Account from the phone then sign back in and try again.
    Let us know how it goes.
    This happens on both wifi and mobile. It's only from the google play store though. I can download files from the web.
    Wiping the Cache partition didn't change anything. Neither did signing out and signing in again
  5. #5
    There can sometimes be server issues. How long has it been going on? I'd give it a day and see what happens.
  1. How do you reply to a text from the lock screen on the galaxy s5?
    By Mariah Richardson in forum Samsung Galaxy S5
    Last Post: 01-23-2016, 02:12 PM
  2. Help with battery drain nexus 5
    By Dayce Manalo in forum Android 4.4 KitKat
    Last Post: 07-02-2014, 07:00 PM
  3. Corporate Exchange Calendar with Nexus 5?
    By Michael_CS in forum Google Nexus 5
    Last Post: 05-29-2014, 09:41 AM
  4. Replies: 1
    Last Post: 05-26-2014, 08:34 PM
  5. Replies: 0
    Last Post: 05-26-2014, 08:30 PM
