1. Timothy Ready's Avatar
    I'm looking for some help for my bionic. I can't get it to power up. At first it would begin splash screen and go no further but now won't even do that. I have removed the battery seveal time, and for differing amounts of time, (up to overnight). I plug in the charger and get the white light on top, but only for a while. I have also tried using my charging stand as well. I have tried factory reset, and all other tricks with no good result. Is the battery dead? I bought this refurbished for about $50 bucks and only use for wifi and tunes etc., but still would like to use the thing.
    Any advice would be appreciated, so thanks and advance,
    Tim
    05-28-2014 12:40 PM
  2. srkmagnus's Avatar
    Tim
    I think it may be the battery. Try a replacement and see if you have success. Let us know how it goes.
    B. Diddy likes this.
    05-28-2014 10:10 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree, battery sounds like the biggest suspect.
    05-28-2014 10:54 PM
  4. Timothy Ready's Avatar
    Thank you both for the advice, I ordered one today. When I get it straitened out I'm gonna be asking how to root it. I had no problems rooting my Galaxy Tab 2 but haven't had any luck so far with the Bionic. I will let you know if the battery works out.
    05-29-2014 03:30 PM
  5. B. Diddy's Avatar
    05-29-2014 03:35 PM
  6. Mooncatt's Avatar
    I did some searching on this, aka the white light of death, and the general consensus is the battery is too drained to do anything and you should charge it a while for the light to go out before the phone will power up. If that's not working, then I agree, replace the battery.
    05-29-2014 09:19 PM
  1. Moto g camera roll shows Grey photos
    By Pat_ai2009 in forum Moto G (2013)
    Last Post: 06-30-2015, 08:54 AM
  2. Droid RAZR M: New Message Flag?
    By paswes in forum Droid RAZR M
    Last Post: 06-13-2014, 12:43 PM
  3. Lots of data being used on my Verizon Droid DNA
    By GNX231 in forum Verizon Droid DNA
    Last Post: 06-01-2014, 08:55 AM
  4. How Is The Moto X Stacking Up?
    By stepaul8 in forum Moto X (2013)
    Last Post: 05-29-2014, 09:05 AM
  5. Moto G widgets acting up
    By UpahUpah in forum Moto G (2013)
    Last Post: 05-28-2014, 12:53 PM
