Results 1 to 2 of 2
    Default Having Problems With My Chargers?
    Right now I have an HTC One M7 and a Nexus 10. I bought both of them used and they didn't come with the original chargers, so instead I am using the ipad charge block connected to a pogo charger for the Nexus and a regular micro sd for the HTC One. The problem I occasionally have occurs when I connect the pogo charger to the Nexus, accidentally disconnect it, and then plug it back it. For whatever reason, it won't charge it after that. Sometimes, but rarely, it won't charge when I plug it in the 1st time. The solution I found was to unplug it from the outlet and move it to the other outlet that is above or below it. This occurred once on my HTC One, but it almost always happens on my Nexus. Is it because I am not using the standard charging block? Are there any solution to this?
    Thanks!
  2. Best Answer
    It's the charger. For some reason the charger is not playing nice with the device and there probably isn't a solution other than the one you are already using to get it working. If possible, get a replacement. OEM is recommended, but not required.
  3. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Having Problems With My Chargers
  1. Google Play Can No longer See My Phone (Galaxy S3/Verizon)
    By Mr. Chicken in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 08-18-2016, 10:36 PM
  2. Yup! I soft-bricked my VM Venture
    By Silver Rivers in forum Android 2.3 Gingerbread
    Last Post: 07-23-2014, 05:04 PM
  3. Since kitkat, bluetooth problems
    By Pattyk999 in forum Droid RAZR MAXX HD
    Last Post: 06-17-2014, 09:29 PM
  4. S5 Car Charger Specs
    By Daniel D1 in forum Samsung Galaxy S5 Accessories
    Last Post: 06-16-2014, 02:45 PM
  5. Getting my free Xperia Z2
    By lazagna in forum Sony Xperia Z2
    Last Post: 05-30-2014, 11:35 AM
