Results 1 to 3 of 3
    Default How to disable Magazine UX on my Tab Pro 8.4?
    I don't really use it and i prefer the normal Android home sceens way better than Magazine UX and it is very limited and have no use for it.
    I would like to disable the Magazine UX on my Tab Pro 8.4.
    And i don't really want to root/custom ROM the Tab Pro 8.4 just to remove Magazine UX.
    Does anyone know how to disable Magazine UX on my Samsung Tab Pro 8.4? How to remove Magazine UX?
    If i can't disable Magazine UX then it won't be a big deal breaker anyway because it does not slow down my Samsung Galaxy Tab Pro 8.4.
  2. Thread Author  Thread Author    #2
    Default Re: How to disable Magazine UX on my Tab Pro 8.4?
    Anyone?
  3. #3
    Simple answer: You can't. The best bet is to just use another launcher (Nova, ADW, Buzz, etc.). Just go to the play store and search for "launcher" and you'll get a host of options, none of which use the Magazine UX tiles. No root is necessary.
  1. [FREE][GAME] Frog Vs. Flies On Google Play
    By AcesOfLife in forum Android Games
    Last Post: 06-02-2014, 11:30 AM
  2. Replies: 7
    Last Post: 06-01-2014, 09:19 AM
  3. Adding a brightness slider to the dropdown menu
    By matannnnn in forum Google Nexus 5
    Last Post: 05-31-2014, 03:09 AM
  4. S3 Won't Sync To Samsung Store
    By Flintstone11 in forum AT&T Galaxy S3
    Last Post: 05-30-2014, 01:14 PM
  5. Google Edition ROM on S4
    By christian729 in forum T-Mobile Samsung Galaxy S4
    Last Post: 05-29-2014, 03:30 PM
