Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By srkmagnus
    Default App problem
    I am trying to login to the The Sun Mobile app however when i click on the password field the app restarts itself over and over.
    i have cleared the data and cache and have done a factory reset but still doesnt work.
    is there another way to login to the app?
    i am using Android version 2.3.6
    Kernel version 2.6.35.7-perf+
    baseband version a4-03.32.01
    And my phone is the Acer liquid metal
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: App problem
    Quote Originally Posted by Ruud00 View Post
    Have you uninstalled/reinstalled? what about check user feedback? Are others have similar issues based on Google Play reviews?
    If there is no fix with an uninstall, I would suggest reporting to the developer for a fix and see how that goes.
    B. Diddy and Golfdriver97 like this.
  3. #3
    Good tips from srkmagnus. It really sounds like a problem with the app, not with your device. Which Sun app is it? Can you show us the link on the Google Play Store?
    Yes i have uninstalled and reinstalled , it was working on my phone months ago then suddenly stopped. So i did a factory reset thinking it must now surely work but still doesnt.
    https://play.google.com/store/apps/d....thesun.mobile
  5. #5
    Really horrible reviews for that app. I seem to remember someone else having this issue a year ago or so. Not sure if it was ever solved.
  1. Why can't I see "All" photos in the Google Photos app?
    By LeighAngela in forum Samsung Galaxy S5
    Last Post: 01-22-2017, 10:53 AM
  2. [App][2.2+] Animal HD Wallpaper Collection
    By ponysoft in forum Entertainment
    Last Post: 08-19-2014, 06:59 PM
  3. What music app are you using?
    By Omer San Gabriel in forum Samsung Galaxy S4
    Last Post: 06-02-2014, 12:30 PM
  4. Charging Problems on my S4
    By Defining in forum Samsung Galaxy S4
    Last Post: 06-01-2014, 10:59 PM
  5. LG Motion 4G: Adb.exe: apps to SD card glitch?
    By crazy_code in forum General Help and How To
    Last Post: 05-31-2014, 04:30 AM
