1. bulldogs195461's Avatar
    just a general question,i need to get a micro sd card for my xperia z2 tablet,im not sure of which class to get,or size of them,although im pretty sure 32 or 64 would suffice.i may download several movies for the kids,all help appreciated,
    cheers john
    06-01-2014 04:32 PM
  2. B. Diddy's Avatar
    Most devices should be able to support up to 64 GB. Not sure about the newer 128 GB microSD cards, though. Most microSD cards I see are class 10, which is good. Stick with well-known brands like Sandisk, Samsung, Toshiba, Patriot, PNY, or Transcend, to name a few. And be careful about ordering them from eBay or from some marketplace seller on Amazon--you're more likely to run into a counterfeit card.
    When you have the card, you can run SD Insight on your device to make sure the card is what it says it is.
  3. B. Diddy's Avatar
    bulldogs195461 likes this.
    06-01-2014 04:38 PM
  1. Which phone has the best GPS??
    By ilikecookies665 in forum General News & Discussion
    Last Post: 12-29-2016, 10:33 AM
  2. Headache with MP3, MP3 tags, and SD cards...
    By zerrisk in forum Android 4.4 KitKat
    Last Post: 01-18-2015, 08:28 AM
  3. Replies: 3
    Last Post: 06-03-2014, 01:14 PM
  4. Need to remove sim card in a LG
    By Nephew Sam in forum General Help and How To
    Last Post: 06-01-2014, 03:30 PM
  5. Headache with MP3, MP3 tags, and SD cards...
    By zerrisk in forum Samsung Galaxy S5
    Last Post: 05-31-2014, 05:31 PM
