1. alimtiaz951's Avatar
    I am using Samsung Star Duos GT-S5282 . I was trying to root it by using a software Kingo root. I had no knowledge of rooting before. Kingo Root just asked me to attach my mobile and click on root button which I did and I found something installing with a green android shape. then on kingo software it said that Root Successful. It would take some time . Please wait. and their was a Finish button. I thought that it is asking me to wait the mobile to restart and then I clicked on finished button . From then when I turn my mobile. It stuck on logo screen. I have tried to go into recovery mode but recover mode is not opening. I can go only into Download mode. I think that I have soft bricked my mobile. How to get away from this logo screen . what should I do? plz help.
    Thanks.
    06-02-2014 03:59 AM
  2. mobilecrackers's Avatar
    Thanks.
    reflash the firmware using Odin in download mode
    06-02-2014 04:10 AM
  3. alimtiaz951's Avatar
    How to reflash the firmware using odin? I told earlier that I am a newbie in this field. doesnt have much knowledge. how can i do reflashing?
    06-02-2014 04:16 AM
  4. mobilecrackers's Avatar
    download your firmware from sammobile
    Firmwares | SamMobile
    this is the common tutorial
    http://forums.androidcentral.com/amb...-via-odin.html
    you can also use kies to update your phone
    06-02-2014 04:18 AM
  5. Pankaj Dahal's Avatar
    Actually what did you do to solve the problem??? I am stuck with the same problem.....
    PS. I would prefer a simpler solution..
    10-20-2014 11:22 PM
  6. Rukbat's Avatar
    If it's a Samsung phone, the simplest solution is to download the Kies version of your ROM and update the phone with Kies. The slightly more complex solution is to download the Odin version of your ROM and flash it with Odin.
    The simplest (but expensive) solution is to pay your carrier to reflash your phone. If the firmware is corrupt, reflashing, by one means or another, is the only way to fix the problem.
    10-21-2014 10:42 PM
  1. Can't download pictures from ext SD card w AFT nor Kies on Mac Mavericks.
    By Daniel Vasku in forum Samsung Galaxy Note 3
    Last Post: 03-24-2015, 09:31 PM
  2. Replies: 23
    Last Post: 10-23-2014, 02:49 PM
  3. How do you delete comments on my android tablet ... ? the youtube comments
    By LanaDelReysboi in forum General Help and How To
    Last Post: 06-02-2014, 09:29 PM
  4. Optimus v stuck in boot animation.
    By Lions2 in forum Virgin Mobile Optimus V
    Last Post: 06-02-2014, 04:50 PM
  5. Get the unreleased WiFi calling for your rooted Sprint GS5
    By Joe113 in forum Samsung Galaxy S5
    Last Post: 06-01-2014, 11:29 PM
