1. Burgomatic Vulgaris's Avatar
    Scenario:
    I am using an app, and then presses the power-button to lock the phone.
    When pressing the power-button to wake up the phone, it resumes the last used app.
    Question:
    How can I make it always return to home screen when it locks?
    HTC One X +
    Android 4.2.2
    06-02-2014 06:52 AM
  2. ShaggyKids's Avatar
    Before you press the home button you have to close whatever app you are in. That is the only way I know how it's done.
    Notes from Deb's Note 3
    06-02-2014 08:03 AM
  3. raptir's Avatar
    It's a bit of a "hack," but if you use a custom lockscreen (like WidgetLocker) or a mod that allows you to change your lockscreen shortcuts (I'm not sure what would be available on the HTC One X, but on the Nexus 5 there are options like GravityBox or ROMs like Cyanogenmod) you can set the unlock action to be "launching an app" and point it towards your launcher. I know that the Google Now Launcher and replacements like Nova and Apex can be handled in this way, not sure about the HTC launcher.
    06-02-2014 09:29 AM
  1. Phantom - how everyone should share
    By Dmitryon in forum The Android Central Lounge
    Last Post: 10-27-2014, 12:10 AM
  2. How to disable google apps in kitkat?
    By xperia2995 in forum Android 4.4 KitKat
    Last Post: 06-05-2014, 08:46 PM
  3. Replies: 3
    Last Post: 06-02-2014, 12:11 PM
  4. Syncing a hard drive to the 12-2
    By popengchan in forum Samsung Galaxy Note Pro 12.2
    Last Post: 06-02-2014, 01:19 AM
