Results 1 to 4 of 4
    Default Samsung galaxy ace problem
    hi,
    my friend told me to root his samsung galazy ace. I am trying to put cyanogenmod on but it does not have a custom recovery on or custom rom on. However, the actual OS on the phone does not boot and is stuck at the words android in white when booting so i cannot enable adb. as a result, i cannot mount USB to computer so put the files in to install. also, i cannot install a custom recovery. When try adb devices, it comes up with. S5830ae3cb945 recovery. However, when i try to flash on cyaogenmod, it comes up with <waiting for device>. Currently i do not see how i can either flash on cyanogenmod or put it in the sd card. I do not have an external sd card reader to plug in to my computer. thanks
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Samsung galaxy ace problem
    I would use Odin to recover your stock ROM. Once you do, and you won't be rooted anymore, you can reroot. Now, most rooting processes have you flash a custom recovery, and it's the custom recovery that you should use to flash CM.
    What instructions did you follow?
    Quote Originally Posted by Golfdriver97 View Post
    hey, thanks for the instructions. I got this from a friend who wanted me to root the device after he failed to do so and left it in this situation. I've never had a samsung device so wasn't aware of the odin thing and download mode. When it came to rooting it, i knew what i was doing.
    Thanks again, only got back to this after my holiday so sorry for the late reply
  4. #4
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Quote Originally Posted by fishbowl38 View Post
    No sweat. Did you get everything sorted out?
  1. Anyone having problems with Air Gestures on Galaxy S5?
    By stargate09 in forum Samsung Galaxy S5
    Last Post: 10-29-2016, 12:28 PM
  2. Can you connect Nexus 7 to Samsung LW series TV
    By 53cambuslang in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-14-2014, 11:52 AM
  3. Sending Multi media message problems
    By Melaney Barter in forum Samsung Galaxy S II
    Last Post: 06-03-2014, 08:29 AM
  4. Galaxy Nexus i9250 problem.
    By aLvindeBa in forum General Help and How To
    Last Post: 06-03-2014, 05:06 AM
  5. samsung galaxy s4 notification update
    By Aica Mandia in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-03-2014, 02:42 AM
