Capturing a video clip on Android phone
diastro
6
Does anybody know how to capture a video clip on Android phone? What Android apps can capture clips?
I'd like to make a video that shows I am working with the desktop, icons, widgets etc.
karmiccalamity
99
7
So it takes a video of you screen?
Would be cool, i haven't heard of anything like that but you could just take screen shots and make a slide show/ powerpoint then to convert to video add voice over
Sent from my DROIDX using Tapatalk
diastro
6
I can't use slides, I need to show some actions on the screen. Meanwhile I found out there was an app that basically controled Android device remotely:
androidscreencast - Project Hosting on Google Code
The only problem is it can do very low fps, which makes it next to impossible to make a good movie.
Anybody knows a better desktop app to control an Android device from a PC (high fps)?
intrimazz
Active member
Jan 18, 2011
28
have you tried Fraps? I know it takes vids from your pc - no idea if it can do it for another device but figured I'd throw it out there for you to evaluate.
MarcosVo
