Has anyone got this to work. Device manager shows device drivers are loaded but I get a hang after trying to start server or a can not start server messages depending on which rooting tool I try.
Andy
Andy
Try uninstalling then reinstalling the drivers. Also, sounds like you are using adb to root? If so, make sure adb is setup properly and and is recognizing the device.Has anyone got this to work. Device manager shows device drivers are loaded but I get a hang after trying to start server or a can not start server messages depending on which rooting tool I try.
Andy
