Results 1 to 3 of 3
    chelsea167's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Senua Digital Reset Help!!!
    I have a senua digital android and one of my kids has put a pattern lock on it which i can't get off. I have tried factory resetting it but it's just brings up the robot with the exclamation mark? Please can someone help??
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,015 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Senua Digital Reset Help!!!
    Welcome to Android Central! Can you tell us the exact model name of the tablet?
    If you can get to the robot with the exclamation mark, you usually have to press the buttons in a certain combination to get to the Recovery Menu. Try pressing Power and Volume Up at the same time, or Power and Volume Down. If there's a Home button, try combinations using that button.
  3. #3
    Graham Myers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: Senua Digital Reset Help!!!
    It won't start up just has symbol on with one arm lit and won't reset
  1. Gear 2 Neo S Voice Help
    By abrown1434 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 01-04-2017, 08:20 PM
  2. I need help with storage on my NP
    By Evilguppy in forum Samsung Galaxy Note Pro 12.2
    Last Post: 07-07-2014, 07:36 AM
  3. HTC One gets stuck on "hTc" screen. please help!
    By android06 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 06-06-2014, 09:21 AM
  4. app help
    By pico360 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-06-2014, 06:30 AM
  5. Please Help! Lost Voice Input...
    By CorvetteTom in forum Samsung Galaxy Note 3
    Last Post: 06-06-2014, 04:46 AM
