1. kerpal131's Avatar
    "I just got an lg g2 and it did several updates immediately. In between each update it worked fine. After the last one to kit Kat. I get an error message that reads "unfortunately the process com.google.process.gapps has stopped" . It also reads in a Spanish/English, everything that happens and every button I press out loud (very annoying). Everytime I press a button it gets circle with a yellow box and I have to double tap the icon for it to open. Also I cannot scroll so when I finally am able to get my setting open, only the first few options are there. Please help this is my buisness phone!!!!
    06-06-2014 01:53 PM
  2. Golfdriver97's Avatar
    Since you just got it, I would suggest a factory reset.
    From a Carbon M8 and AC Forums app
    06-06-2014 04:16 PM
  3. Rukbat's Avatar
    If the factory reset doesn't do it, your carrier is responsible for the update, so bring it to them and ask them to reflash the phone, fix the problem or replace the phone - their choice. (They're legally obligated to "make you whole" when they damage your property - which THEIR update did.)
    06-07-2014 10:59 PM
  1. Senua Digital Reset Help!!!
    By chelsea167 in forum General Help and How To
    Last Post: 03-03-2015, 10:42 AM
  2. camera zoom not working "HELP"
    By LaVerne Boylan in forum Samsung Galaxy S5
    Last Post: 06-06-2014, 01:37 PM
  3. group texting help!
    By covrec1 in forum General Help and How To
    Last Post: 06-06-2014, 12:36 PM
  4. Please Help! Lost Voice Input...
    By CorvetteTom in forum Samsung Galaxy Note 3
    Last Post: 06-06-2014, 03:46 AM
