Using one SIM card for multiple phones, is it possible to do without having to deal with Verizon?
CannedBullets
274
So if I want to use the SIM card from my contract HTC One M8 for multiple phones to keep the same number. Would it be possible to do so without having to deal with Verizon? Also, as soon as I sign into Google, I'd have all my contacts right?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Sure, but each phone would have to have an account. Verizon is CDMA, not GSM. The SIM card is for data, not for network connection. You'd have to change your account's current ESN (which is on the box the phone comes in and on a label under the battery on phones that have removable batteries. (And a dial code, which is different for different manufacturers.)
Verizon used to have someplace on the website to do the change (after you log in). If they don't still do that, you'd have to call customer service every time you wanted to swap phones.
mamawM
234
13
yes, you can swap them, as long as both phones use the same type of sim. just put the sim in whichever phone you want to use and go on about your business, when you're ready to switch back, just go for it. i've done it several times. no problems.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Correct, I do the same
dpham00, Android Central Moderator
Sent from my Verizon Moto G
MarcosVo
