1. Mark Lucas1's Avatar
    Hi,
    I've been trying to find a solution but cant, Ive always been an iphone fan until their battery issues got the better of me and i swapped to Note 3, ive never looked back. The only draw back i can see ATM is the issues im having adding music albums to my phonr using Kies3. You cant seem to edit an album or add to it or rename it. The other day i added an album and each song was added individually. I cant find an option like on itunes where you can rename the album and group all songs that you want in it. now i have an album called music with 2 albums in there?? lol any help would be amazing
    thanks
    06-08-2014 05:20 AM
  2. Golfdriver97's Avatar
    Hi,
    thanks
    Welcome to the forums.
    I think Play Music Manager might help out here. Free from Google, you download it to your PC, and then it can help transfer your music from iTunes.
    06-08-2014 10:27 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Yes, Google Music Manager is useful to upload all of your music to your Google Music Library in the cloud. From there, you can easily edit your albums and songs, and download them to any device or computer.
    If you want to transfer songs or albums directly from your computer to your device, it should be easy to connect via USB and use your computer's file manager to drag and drop the music files. Keep the standard folder hierarchy of Artist/Album/Song.
    Posted via Android Central App--please excuse the brevity and any typos!
    Golfdriver97 likes this.
    06-08-2014 11:40 AM
  1. Android (overall) Sync
    By rrudeboy in forum Moto X (2013)
    Last Post: 06-07-2014, 11:42 PM
  2. Best Tether App for Note 3
    By Don164 in forum General News & Discussion
    Last Post: 06-07-2014, 08:58 PM
  3. Android Messaging App Help
    By Ryan Stewart4 in forum Android 4.4 KitKat
    Last Post: 06-07-2014, 08:16 PM
  4. Replies: 8
    Last Post: 06-07-2014, 07:12 PM
