1. saikene's Avatar
    Hi,
    I have an LG Lucid. The power button on it has been broken for a while now. Just recently I decided to plug it into a charger to see what would happen, and what do I know, the phone boots up right away instead of going to the typical battery charging screen. I cannot replicate this now, and I'm wondering how it happened the first time, and what I can do to have it work again.
    Any help would be greatly appreciated.
    06-08-2014 07:11 AM
  2. Paul627g's Avatar
    Not sure how to replicate that. Sounds like you got lucky because simply plugging in a device that is completely discharged or turned off shouldn't power it on other than showing the charging animation.
    06-08-2014 08:50 AM
  3. Rukbat's Avatar
    It sounds as if, just as you plugged the charger in, you jostled the power switch enough to make it make contact long enough to turn the phone on. You'd actually have to modify the hardware in the phone to get a "boot on power" function. It would be far easier to replace the power switch.
    06-08-2014 05:05 PM
  1. Replies: 3
    Last Post: 06-13-2014, 02:32 AM
  2. how to completely move apps to an sd card?
    By Jakk0 in forum Samsung Galaxy S5
    Last Post: 06-08-2014, 02:06 PM
  3. Replies: 4
    Last Post: 06-08-2014, 10:21 AM
  4. saving pics from camera to sd card
    By Delen Mahesparan in forum Samsung Galaxy S5
    Last Post: 06-08-2014, 07:03 AM
  5. Using phone as GSM-modem?
    By Teddy Brask-Andersen in forum Samsung Galaxy S4 Active
    Last Post: 06-08-2014, 05:24 AM
