Turn off startup tune on ZTE: Radiant 740
Petebo
RE: ZTE Radiant 740 Is there a way to turn off the AT&T start up tune when first turn on the phone other than just turning off the sound when shutting it down?
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Re: Turn off startup tune
I'm almost certain this would require you to be rooted and go in and delete the startup sound file.
Mooncatt
Ambassador
Feb 23, 2011
10,751
311
83
I use an app called "Android Assistant", it's a suite of functions and one of them is a startup manager that allows for silent startup and shutdown. I don't have to be rooted for that function on my Bionic.
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Thanks for recommending this. Love it when the community steps in and comes up with a solution :D
merryrain51
4
So I had the same question wanting to turn that very LOUD start up tune. Saw the answer about the Android Assistant. But which of the start up choices do you pick to get a silent start up?
Mooncatt
Ambassador
Feb 23, 2011
10,751
311
83
I'm baaaccckkk! I followed the instructions, chose silent startup option but that annoying, very loud start up music still happens. What am I doing wrong?
Hard for me to guess since I'm not familiar with that particular phone. It may have something to do with the OS not letting Android Assistant access the volume control. You may want to try emailing the developer.
jcl678
