Results 1 to 2 of 2
    knusto's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default alps 809t
    My alps 809t has got invaded by some obscure app. I uninstall, but it comes back, installs without asking. What can I do to get permanent rid of it?
    Some screenshots:
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,015 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: alps 809t
    Welcome to Android Central! I suspect some other app that you installed is causing this one to piggyback. Do you recall installing some other app around the time this unwanted one showed up?
    You may need to uninstall your most recent apps one by one until you find that this rogue app no longer installs on its own. You could also install a good antivirus app like Lookout, but it won't necessarily find a true virus.
    Posted via Android Central App--please excuse the brevity and any typos!
  1. ALPS MT6517 iPhone 5 clone USB Installation
    By Popola in forum General Help and How To
    Last Post: 09-10-2016, 04:38 AM
  2. Snowman Alps Go locker
    By gopineom in forum Wallpapers, Ringtones, and Themes
    Last Post: 08-12-2013, 10:52 AM
  3. Request Widget/App: Mimic ALP touch/slide/release
    By FireFighterChen in forum Android Apps
    Last Post: 07-04-2010, 04:19 PM
