Results 1 to 6 of 6
    Default Android USB Storage
    Hello my tablet is experiencing problems.
    I plug it into my computer with the USB Cable provided when I bought it and it always worked but now it somehow doesn't connect.
    I can see the storages in my computer but on my tablet I have to click a little button : Turn on USB Storage and that doesn't work. It keeps loading.
    This is annoying because I can't look inside the maps on my tablet since it wont allow access.
    Is there a way to disable my tablet asking permission or is there a way to fix the Turn on USB button ?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,726 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Android USB Storage
    Quote Originally Posted by Headless Joey View Post
    Welcome to the forums.
    When you go into Settings>Storage, and click menu, you should see USB computer connection. Is MTP checked?
    Yes I can check MTP then it connect, but I can't put anything inside because I have to reformat, and I can't do that in MTP mode.
  4. #4
    Posts
    Global Posts
    32,726 Global Posts
    Carrier
    Not sure what to suggest to do next. Sorry.
    From a Carbon M8 and AC Forums app
  5. #5
    Could it be that the phone isn't recognizing the map file type?
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    You have to reformat the internal storage of the tablet? Why?
  1. Replies: 7
    Last Post: 09-29-2014, 04:28 AM
  2. Getting the one m8 back to standard android?
    By g12528 in forum HTC One M8
    Last Post: 06-12-2014, 07:44 PM
  3. Help! Android Browser has a Black Bar on Top
    By kouhei07 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-09-2014, 07:41 PM
  4. Meaningful Android 4.4.3 improvement on M8 GPE.
    By EWY in forum Google Play edition HTC One M8
    Last Post: 06-09-2014, 01:02 AM
  5. [Free Game] Beer Master-really addictive android game
    By 2imagineCreations in forum Android Games
    Last Post: 06-09-2014, 12:34 AM
