1. careingemt's Avatar
    Any one know how to create a WI Fi profile with tasker
    to turn WI Fi on when I arrive home turn off when I leave home.... Not turn WI Fi on till I get home ive tried everything plz help
    I've created it with cell near click scan home wifi shows up I select it when I arrive at work it connects to wife at work.... I only want it to connect to my home
    Tried it with WI Fi connect.... Same thing
    cell
    06-09-2014 07:56 PM
  2. Golfdriver97's Avatar
    cell
    Setting it by cell signal is hit and miss for me, too. I set up a time frame, but in reverse. When I normally leave for work I have WiFi set to go off, and then I put in an Exit task. The exit task helps with the midnight wrap around.
    Did the same thing for the Mobile data connection.
    I can provide a screenshot if you need it.
    From a Carbon M8 and AC Forums app
    06-09-2014 08:01 PM
  3. careingemt's Avatar
    Please
    cell
    06-09-2014 08:02 PM
  4. Golfdriver97's Avatar
    Here you go.
    06-09-2014 11:26 PM
  1. Tasker
    By careingemt in forum Droid RAZR
    Last Post: 11-23-2014, 12:40 PM
  2. Using AppLauncher with Tasker
    By lizardchest in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-06-2014, 12:16 AM
  3. Help with Tasker
    By careingemt in forum General News & Discussion
    Last Post: 06-19-2014, 06:12 PM
  4. Tasker Help... Enable quiet mode but allow notification lights still?
    By jgordon00 in forum General Help and How To
    Last Post: 05-31-2014, 09:15 PM
  5. Tasker
    By careingemt in forum General Help and How To
    Last Post: 05-22-2014, 12:40 AM
