1. Tess Trotter's Avatar
    Hi there :-) I just bought a new phone: Huawei Ascend Y320 today, running android 4.2. It only came with a quick start guide, no comprehensive instructions. So far its been pretty intuitive, but I can't figure out how to download apps. I have a thing called goggle play, which seems to be where this happens, but if I search for an app (i.e. facebook) and click install, nothing happens. Any ideas anyone? Also, when I open google play, it has a loading (circle spinning) symbol, which never ends and the page is blank. Wondering if that is the issue, or if I set up the google login incorrectly? Thanks in advance.
    06-10-2014 02:59 AM
  2. Kelly Burby's Avatar
    Ooh... com'on this isn't that much tough well what you need to do is open the playstore tap over the search button on the top right corner type the application name you want to install say "Facebook" it will show you the result tap on the very first application a page will open showing application and in the middle of the screen you can see the option Install tap over that option, accept the permissions and all done wait for the application to finished installing that's all . Go to the home screen and enjoy the application you have installed.
    06-10-2014 04:45 AM
  3. chethantr's Avatar
    sorry i am new member of this forum and not able to post my problem i am facing. so i am replying to this .
    i have a small problem. a small icon is showing always on my android phone as show in the image. what is it and how to remove it.
    thanks, Chethan
Name:	My Phone image 2.jpg
ID:	122536Click image for larger version.
    06-10-2014 08:23 AM
  1. Lockdown Pro - app lock, lock screen, time pin, observer, send mail
    By kenzi100c in forum Android Security Apps, Tips & Strategies
    Last Post: 07-09-2014, 01:53 AM
  2. A Super App To Change Fonts
    By Greg C in forum Samsung Galaxy S5
    Last Post: 06-16-2014, 10:25 AM
  3. S4 takes one minute to dial a number
    By Paul Stavrou in forum Vodafone Samsung Galaxy S4
    Last Post: 06-16-2014, 05:22 AM
  4. HTM M3 As a Second Phone?
    By Nickdi in forum General News & Discussion
    Last Post: 06-10-2014, 08:25 PM
  5. New Free COOL Game - PIXEL SAGA- Which combine the top games
    By aa apps in forum Android App Inventor
    Last Post: 06-10-2014, 01:54 AM
