asteroid atc64 4g
dave hopkins
Hi.
Just bought a new asteroid atc64 4gb...I'm trying to get the web cam to work so i can skype or chat to friends on line. The Camera works fine but unable to get cam working. I can see others on cam but not myself.please help. it has to be a simple reason,
Thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,536
4,673
113
Welcome to Android Central! I'm not familiar with that brand at all--with these lesser known manufacturers, there tend to be more hardware and/or software flaws, which might cause various problems.
Are you saying that your front-facing camera (i.e., the one you use to Skype) doesn't work at all? Are you sure it even has a front-facing camera? Open the Camera app and look at its settings--see if there is an option to toggle between the rear- and front-facing cameras. The icon usually looks like a device with a curved arrow around it. If there is no option to swap in the Camera app, then it's likely that you don't have a front-facing camera, or the firmware doesn't recognize it.
