1. elieobeid7's Avatar
    I have a rooted S3 mini, android version 4.1.2, link2sd free edition installed. S3 mini doesn't support moving apps to SD so I have to use Link2SD. I have 4 GB sd and I have followed the instructions in this video to partition it
    Today, I have bought a 64 GB SD card to replace the 4 GB sd card that I have. At about the second minute of the video, the guy says you can go as high as 2 GB for your apps.
    My question is, can you go higher than that? can you link say 16 GB of apps to SD using link2SD? I have 64 GB card so 2 GB is nothing, my internal memory is 8GB so I need that extra space.
    06-10-2014 04:25 AM
  2. srkmagnus's Avatar
    I would imagine that there is no limit as to how much external storage you can use for Apps so as long as the partition is large enough to accommodate the number of Apps you wish to install.
    06-16-2014 10:21 AM
  1. Lockdown Pro - app lock, lock screen, time pin, observer, send mail
    By kenzi100c in forum Android Security Apps, Tips & Strategies
    Last Post: 07-09-2014, 01:53 AM
  2. [free][android/ios][game][app] I ATE COLORS
    By dangerouspea in forum Android Apps
    Last Post: 06-16-2014, 03:38 AM
  3. Default Message App
    By Greg C in forum Samsung Galaxy S5
    Last Post: 06-10-2014, 05:27 PM
  4. Help to load apps to new phone
    By Tess Trotter in forum General Help and How To
    Last Post: 06-10-2014, 08:23 AM
