Results 1 to 3 of 3
    Default GPS not working on LG Optimus G (E970)?
    I just got an LG Optimus G (E970) and I can't seem to get the GPS to locate me. I never seems to be able to get a signal. The GPS doesn't work on any apps. It's Unlocked and I'm running it on MetroPCS 4G LTE network. How can I fix my problem??
  2. #2
    Default Re: GPS not working on LG Optimus G (E970)?
    well, all i know is that to get the signal, you have to have an app open for the gps. i use google maps. just wait a while. fyi the gps on the device does not have anything to do with the 4g network. all the data does is load the map. you can just swipe around on wifi and let it load a bit, then go off wifi and it will work just fine (i think). + really great choice. i <3 the lg optimus g. amazing device right?
  3. #3
    Quote Originally Posted by FiretoFlames View Post
    Hey ive experienced that. So I was in a moving car and I couldn't get a signal. =( but when I stopped somewhere, it connected =) just something to think about. I doubt it has anything to do with it
  1. Fix LG G2 Signal Issues with Root and Rom?
    By one eye bear in forum Sprint LG G2
    Last Post: 10-13-2015, 02:23 AM
  2. Replies: 6
    Last Post: 07-16-2014, 07:53 AM
  3. Lg G2 knock code update - without kitkat
    By 3m1100 in forum LG G2
    Last Post: 06-14-2014, 09:15 AM
  4. Replies: 1
    Last Post: 06-14-2014, 03:20 AM
  5. Google Now not working via Bluetooth...
    By graysonk95 in forum Samsung Galaxy S4
    Last Post: 06-10-2014, 10:57 PM
