Results 1 to 6 of 6
    Default Lightning Launcher - hide notification bar?
    Is there a way to hide the notification bar in Lightning Launcher? To not have it visible from the desktop, but still able to pull it down when needed. (without rooting)
    I had been using Nova, which has the option. I have recently switched to LL and while I enjoy the many added features, I have yet to be able to find this one.
    Thanks in advance.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,670 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Lightning Launcher - hide notification bar?
    Quote Originally Posted by starry_night View Post
    Thanks in advance.
    Welcome to the forums.
    Have you emailed the developer with the suggestion?
    I have not. I wanted to make sure that I was not just missing it. As I sometimes do. Since no one has posted "here it is" yet, I will assume that it is not included at this time. So I will email the developers.
    Thanks!
    Just a quick follow up to help anyone else as blind as I was....
    It is included. (response from developer):
    "I think the option you are looking for is in the "Miscellaneous" category ("Hide the status bar"). Sorry if it is a bit hidden... In order to display it again you can assign the "Toggle status bar" to a gesture, key press or icon, or you can also use the "Expand notification tray" action if you want to see this panel too.
    Hope this helps"
    Golfdriver97 likes this.
  5. #5
    Posts
    Global Posts
    32,670 Global Posts
    Carrier
    Thanks for the follow up.
    From a Carbon M8 and AC Forums app
  6. #6
    Am also facing this same problem, when you got some useful answer, please let me know..
  1. Notifications not appearing since using ultra power save mode
    By martinmacrae83 in forum Samsung Galaxy S5
    Last Post: 07-23-2016, 01:45 AM
  2. Galaxy s4 Loses Service Without Notification
    By neomaster41309 in forum AT&T Samsung Galaxy S4
    Last Post: 10-14-2014, 04:49 PM
  3. How to remove NO SIM NOTIFICATION
    By kchtwd09 in forum Sprint Samsung Galaxy S4
    Last Post: 07-01-2014, 04:53 PM
  4. Problem with WhatsApp Notification
    By shikhar10882 in forum Google Nexus 5
    Last Post: 06-11-2014, 03:59 AM
  5. Galaxy S5: Notification Help Please....
    By TripleB67 in forum Samsung Galaxy S5
    Last Post: 06-10-2014, 09:04 PM
