Results 1 to 4 of 4
    Default Contacts on my S5
    I recently upgraded from an S4 to an S5. Now along with the S5 I also purchased a Tab 3. I am trying to synch my contacts now between both. It turns out that the contacts now on the S5 are device oriented and will not synch. How do I go from Device oriented contacts to contacts associated with my Google account without manually re-entering all contact information?
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Default Re: Contacts on my S5
    Quote Originally Posted by jmagid51 View Post
    Have you tired putting the same gmail account you have used with S4 to S5 and tab3??? I would say just put the same gmail account that you have used and all will be synchronized automatically.
    I tried an experiment and added a new contact on my S5 but instead of saving to "device" I saved it to my Google address. It worked fine. Now I am looking for a way to move my other contacts that were "deviced" based to that same Google address. How is that done with an existing contact?
    Problem solved ... but I cheated. I exported all of my contacts to an SD card. I them imported the same contacts back under my Google account. All is well but I am sure there is a better way to do it.
  1. Replies: 3
    Last Post: 02-13-2015, 03:50 PM
  2. Charger shuts down after a few seconds on standby
    By Michael Ayling in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-15-2014, 07:01 AM
  3. 4K video on the S5 not as good as the Note 3
    By jennifercolemanme in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 02:56 AM
  4. Samsung galaxy s5 problems
    By sharkcity280 in forum Samsung Galaxy S5
    Last Post: 06-12-2014, 11:03 AM
  5. Galaxy S5 Active Caught On Ebay
    By JSG59 in forum Samsung Galaxy S5
    Last Post: 06-12-2014, 12:43 AM
