Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By B. Diddy
  • 1 Post By mumfoau
    mumfoau's Avatar
    Posts
    Global Posts
    4,516 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Settings Sticking (LG G2)
    I have a Verizon G2! Under my Google account in settings I can go in and uncheck "Google photos auto backup" and "Google+ photos" to prevent them from syncing but go back later and see them checked again. I'm not sure if that happens after I enter the Google+ app or not but when I was on android before that seemed to be the case. To that end, I stopped using Google+ altogether! How can I make those settings stick? I don't want the pics from my phone (nothing explicit or anything) to be on Google+ or any other online medium!
    Sent from my LG G2 using Tapatalk
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Settings Sticking (LG G2)
    You might have to make sure the Auto Backup setting is off in the Google+ settings, not in the account settings. Go to Google Settings (look for it in the App Drawer), then Google+, then Auto Backup, and turn the switch off.
    As for the Google+ Photos sync, as long as the Auto Backup setting is off, it shouldn't sync any of the photos on your phone over to the web--it should only allow access to your cloud albums on the phone.
    mumfoau likes this.
    mumfoau's Avatar
    Posts
    Global Posts
    4,516 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    thanks Diddy! I do have auto backup switched off in Google settings so I reckon I'm good to go!
    B. Diddy likes this.
  1. Replies: 12
    Last Post: 07-15-2014, 12:00 AM
  2. Set default install location to SD card
    By Lions2 in forum Virgin Mobile Optimus V
    Last Post: 06-14-2014, 10:33 AM
  3. how to set fixed wallpaper at multi home screen on nexus5
    By pj16cool in forum Ask a Question
    Last Post: 06-14-2014, 07:19 AM
  4. LG Optimus L3 stuck in a boot loop
    Last Post: 06-14-2014, 03:03 AM
  5. LG Optimus L3 stuck in a boot loop
