Results 1 to 5 of 5
    Default SD card issue
    Hi all,
    I just got a new Samsung trend plus and after inserting the SD card l can't add any files to. After l connect it to my pc it opens the windows explorer but l can't see the SD card. l did format the card in the phone but how can I get to the see the card to move files on it?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: SD card issue
    It could be a defective or counterfeit SD card. Since you can't write to it (in the phone or with Windows) you can't test it. Contact whoever you got it from for a replacement.
    After several attempts (inserting in and out) I see the phone can finally detect it and have now placed some files on it, I have contacted the online shop I bought it and see what they say. As this is a new phone I needed to root it.
    Do you know any software that can examine the card to make sure its not faulty?
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Quote Originally Posted by kmtm View Post
    Ask them for a signed letter stating that rooting the phone will not void the warranty. (It does, but if they're willing to warranty it themselves after you root it, that's on them.) The only time rooting will have any effect on the SD card is if you're running Android 4.4 or higher, and that's the wrong way to fix the problem Google created.
    On a computer:
    h2testw
    On the phone:
    A1 SD Bench, SanDisk Memory Zone, SD Insight (press the "eye" in the upper-right of the screen, then look for the manufacture date - if it was made before that size card came out, it's counterfeit) and SD Tools.
    kmtm likes this.
    thanks for the help I'll try them both
  1. SMS Contact Photo Issue with Google Hangouts
    By Wjjd225 in forum Samsung Galaxy S5
    Last Post: 01-21-2015, 09:39 AM
  2. LTE Issues
    By Fathertime in forum HTC One M7
    Last Post: 06-16-2014, 10:20 AM
  3. Nexus 5 16 GB stock issues?
    By jdevenberg in forum Google Nexus 5
    Last Post: 06-14-2014, 11:02 AM
  4. Set default install location to SD card
    By Lions2 in forum Virgin Mobile Optimus V
    Last Post: 06-14-2014, 10:33 AM
  5. Slideshow app that will pull from my SD card?
    By MADDROID1 in forum Ask a Question
    Last Post: 06-14-2014, 01:19 AM
