Hi Folks, I was helping a friend flash his note back to stock Kitkat and now it is stuck in Odin Mode. I have tried CWM and a few other recoveries, but they all fail in Odin.
This is what ODIN says when trying to flash stock kitkat
<ID:0/008> aboot.mbn
<ID:0/008> NAND Write Start!!
<ID:0/008> FAIL! (Auth)
<ID:0/008>
<ID:0/008> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
When I try to flash CWM or Philz touch recovery I get this from ODIN:
0/008> recovery.img
<ID:0/008>
When trying CWM phone shows sys rev check fail: no version
secure magicode check fail: recovery
Update: I believe the issue was that every file that stated it had the most up to date bootloader was not the correct one i needed. I was about to give up, and I tried one more file and it fixed the phone as far as I can see. file was found at
http://pr32.rapidgator.net//?r=download/index&session_id=kdHq7DsKlGrHPtfIIUqPI7GrRl5lB2Bz
Any suggestions would be appreciated.
<ID:0/008>
0/008> recovery.img
<ID:0/008>
