1. theamericanjedi's Avatar
    Hi Folks, I was helping a friend flash his note back to stock Kitkat and now it is stuck in Odin Mode. I have tried CWM and a few other recoveries, but they all fail in Odin.
    This is what ODIN says when trying to flash stock kitkat
    <ID:0/008> aboot.mbn
    <ID:0/008> NAND Write Start!!
    <ID:0/008> FAIL! (Auth)
    <ID:0/008>
    <ID:0/008> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    When I try to flash CWM or Philz touch recovery I get this from ODIN:
    0/008> recovery.img
    <ID:0/008>
    When trying CWM phone shows sys rev check fail: no version
    secure magicode check fail: recovery
    Update: I believe the issue was that every file that stated it had the most up to date bootloader was not the correct one i needed. I was about to give up, and I tried one more file and it fixed the phone as far as I can see. file was found at
    http://pr32.rapidgator.net//?r=downl...qPI7GrRl5lB2Bz
    Any suggestions would be appreciated.
    06-15-2014 11:36 PM
  2. AndroidProf's Avatar
    Try flashing in the PIT file that can be found on this thread: [GUIDE] VZW Note III Edition XDA Developers (Google it,since we are not allowed to paste links). After you have flashed in the PIT file, simply flash in the recovery file depending upon the version it was previously on.
    06-16-2014 02:22 AM
  1. Multi-Window on Galaxy S5 won't turn on ???
    By Ur2beutiful in forum Samsung Galaxy S5
    Last Post: 10-18-2014, 04:33 AM
  2. Reply to sms from Gear 2 NEO
    Last Post: 08-26-2014, 08:56 PM
  3. Stupid fast battery drain...help?
    By styfyle in forum Sprint Galaxy S III
    Last Post: 06-30-2014, 10:01 PM
  4. Full Cycle Charge on Galaxy S5?
    Last Post: 06-15-2014, 11:05 PM
  5. Samsung Galaxy Note 2 With beat by dr dre
    Last Post: 06-15-2014, 10:38 PM
